[QGIS-trac] [Quantum GIS] #2009: OGR Database Connection MySQL
Quantum GIS qgis at qgis.org
Tue Oct 13 19:24:52 EDT 2009
   Reporter:  elewis52                          |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:
  Component:  Vectors                           |            Version:  HEAD
   Keywords:  mysql database                    |   Platform_version:  Ubuntu 9.04 64-bit
   Platform:  Linux                             |           Must_fix:  No
Status_info:  0                                 |
 Cannot connect QGIS to a MySQL database. Steps to reproduce: Select "add
 vector layer". Select "database" under source type. Select MySQL as
 database type. Enter name, host, database, port, username, password under
 the "Create a new OGR Database Dialogue". Select "test connect". Message
 comes up "Connection failed ... Access denied for user '(my
 name)'@'localhost' (using password: no.) "Using password: no" is obviously
 an error. I connect to the database in question routinely using other
 database clients. The GUI appears not to be properly sending the password
 to the database server.
 A workaround is to connect to the database through GRASS.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2009>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
