[QGIS-trac] [Quantum GIS] #2021: [FreeBSD] problem compiling Qgis
with grass. Kpty.c qtermwidget
Quantum GIS
qgis at qgis.org
Sat Oct 17 12:40:11 EDT 2009
#2021: [FreeBSD] problem compiling Qgis with grass. Kpty.c qtermwidget
Reporter: slash | Owner: nobody
Type: bug | Status: new
Priority: critical: causes crash or data corruption | Milestone:
Component: Build/Install | Version: 1.3.0
Keywords: freebsd grass | Platform_version: 8.0
Platform: FreeBSD | Must_fix: Yes
Status_info: 0 |
On FreeBSD 8.0RC1 (i don't know for older version) you can't compile Qgis
with Grass option.
There is a problem with kpty.c file in qtermwidget
[ 77%] Building CXX object
src/plugins/grass/CMakeFiles/grassplugin.dir/qtermwidget/kpty.o
/usr/ports/graphics/qgis/work/qgis-1.3.0/src/plugins/grass/qtermwidget/kpty.cpp:
In member function 'void KPty::login(const char*, const char*)':
/usr/ports/graphics/qgis/work/qgis-1.3.0/src/plugins/grass/qtermwidget/kpty.cpp:489:
error: 'utmpname' was not declared in this scope
/usr/ports/graphics/qgis/work/qgis-1.3.0/src/plugins/grass/qtermwidget/kpty.cpp:490:
error: 'setutent' was not declared in this scope
/usr/ports/graphics/qgis/work/qgis-1.3.0/src/plugins/grass/qtermwidget/kpty.cpp:491:
error: 'pututline' was not declared in this scope
/usr/ports/graphics/qgis/work/qgis-1.3.0/src/plugins/grass/qtermwidget/kpty.cpp:492:
error: 'endutent' was not declared in this scope
/usr/ports/graphics/qgis/work/qgis-1.3.0/src/plugins/grass/qtermwidget/kpty.cpp:493:
error: 'updwtmp' was not declared in this scope
In member function 'void KPty::logout()':
/usr/ports/graphics/qgis/work/qgis-1.3.0/src/plugins/grass/qtermwidget/kpty.cpp:539:
/usr/ports/graphics/qgis/work/qgis-1.3.0/src/plugins/grass/qtermwidget/kpty.cpp:540:
/usr/ports/graphics/qgis/work/qgis-1.3.0/src/plugins/grass/qtermwidget/kpty.cpp:541:
error: 'getutline' was not declared in this scope
/usr/ports/graphics/qgis/work/qgis-1.3.0/src/plugins/grass/qtermwidget/kpty.cpp:558:
/usr/ports/graphics/qgis/work/qgis-1.3.0/src/plugins/grass/qtermwidget/kpty.cpp:560:
*** Error code 1
Stop in /usr/ports/graphics/qgis/work/qgis-1.3.0.
*** Error code 1
*** Error code 1
*** Error code 1
Stop in /usr/ports/graphics/qgis.
*** Error code 1
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2021>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
