[QGIS-trac] Re: [Quantum GIS] #1934: Unable to remove shapefile
 field in Attribute table
    Quantum GIS
    qgis at qgis.org
    Sun Sep 20 19:27:05 EDT 2009
#1934: Unable to remove shapefile field in Attribute table
        Reporter:  trapanator                        |         Owner:  nobody
            Type:  bug                               |        Status:  closed
        Priority:  major: does not work as expected  |     Milestone:  Version 1.4.0
       Component:  Vectors                           |       Version:  HEAD
      Resolution:  wontfix                           |      Keywords:
Platform_version:                                    |      Platform:  Debian
        Must_fix:  Yes                               |   Status_info:  0
Changes (by jef):
  * status:  new => closed
  * resolution:  => wontfix
Comment:
 QGIS queries the provider, if I can delete attributes.  Depending on it's
 response the buttons are enabled or disabled.  For the shape case OGR
 cannot delete attributes and therefore the button is disabled.  Once
 support is added to OGR, QGIS will use it.  So I'm closing this ticket.
 See also [http://trac.osgeo.org/gdal/ticket/2671 GDAL ticket #2671]
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1934#comment:3>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
