[QGIS-trac] [Quantum GIS] #1945: Qgis crashes removing GRASS raster
 layer from map canvas
    Quantum GIS
    qgis at qgis.org
    Wed Sep 23 04:14:05 EDT 2009
#1945: Qgis crashes removing GRASS raster layer from map canvas
   Reporter:  juanelz                                    |              Owner:  nobody
       Type:  bug                                        |             Status:  new
   Priority:  critical: causes crash or data corruption  |          Milestone:
  Component:  Rasters                                    |            Version:  1.3.0
   Keywords:  GRASS rasters                              |   Platform_version:
   Platform:  Windows                                    |           Must_fix:  Yes
Status_info:  0                                          |
 I installed QGIS Mimas 1.3.0 (OSGeo4W setup, advanced installation with
 qgis-grass-plugin 1.0.2-2 and grass 6.4.0svn3) on Vista 32bit, Vista
 64bit, and XP.
 After loading GRASS raster layers to the map canvas via GRASS Tools QGIS
 crashes if you try to remove the layer (right mouse click on the layer in
 the map legend window). After the crash the file .gislock is written into
 the mapset of the GRASS database. This file has to be deleted manually,
 otherwise it is no longer possible to enter the GRASS mapset.
 The bug is always reproducable on the Vista 32 and 64. On XP I could
 successfully remove several raster layers before QGIS also crashed. This
 bug fix would be a considerable improvement for GRASS plugin and GRASS GIS
 integration on Windows.
 Regards.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1945>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
