[QGIS-trac] [Quantum GIS] #2616: Categorized new symbology
transparency settings
Quantum GIS
qgis at qgis.org
Thu Apr 1 01:25:57 EDT 2010
#2616: Categorized new symbology transparency settings
Reporter: jctull | Owner: mhugent
Type: enhancement | Status: new
Priority: minor: annoyance | Milestone: Version 1.5.0
Component: Printing | Version: HEAD
Keywords: categorized new symbology transparency | Platform_version: 10.6.3
Platform: OS X | Must_fix: No
Status_info: 0 |
Using the new symbology with categorized data does not provide a
convenient means to set a single transparency value for all levels at
once. Instead, you have to go through each item and toggle the
transparency setting to the desired level. This can take quite some time
if there are numerous categories. It would be better to have a global
setting, then allow users the option of setting per level transparency
from the property dialog for a given level.
Additionally, not having the ability to type in a numeric value for the
transparency setting makes setting exact values very difficult. Two
things: 1) make the setting an editable value so users can type in an
exact value; 2) do not carry the setting to so many decimal points - whole
integers seems perfectly adequate for setting transparency amounts.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2616>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
