[QGIS-trac] [Quantum GIS] #2647: New Symbology: Attribute
 Classifcation Field not labeled
    Quantum GIS
    qgis at qgis.org
    Tue Apr 13 06:05:08 EDT 2010
#2647: New Symbology: Attribute Classifcation Field not labeled
   Reporter:  cmoe                              |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.5.0
  Component:  Symbology                         |            Version:  HEAD
   Keywords:                                    |   Platform_version:
   Platform:  All                               |           Must_fix:  Yes
Status_info:  0                                 |
 In the old symbology, the attribute table shows a select box with the
 labels of the classified field, when Classification is chosed as edit
 widget.
 In New Symbology the select box shows the value of the field and not the
 label that is given for this value.
 The old behaviour is imho better, it allows both, to show the value
 directly or to show the label, so the new symbology should adapt it.
 Example: A table with a field 'type' has values 0,1,2. Classified as
 unique type over the field type gives three classses. Labeling them
 0=Car,1=Bus,2=Bike gives in the select box edit widget of the old
 symobology the values Car, Bus, Bike, in the new symbology it gives 0,1,2.
 => the labels are much handier.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2647>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
