[QGIS-trac] Re: [Quantum GIS] #2621: eVis Event Browser missing records
Quantum GIS qgis at qgis.org
Thu Apr 15 17:26:19 EDT 2010
        Reporter:  Donkagen2                         |         Owner:  ersts
            Type:  bug                               |        Status:  assigned
        Priority:  major: does not work as expected  |     Milestone:  Version 1.5.0
       Component:  C++ Plugins                       |       Version:  HEAD
      Resolution:                                    |      Keywords:
Platform_version:  Windows                           |      Platform:  All
        Must_fix:  No                                |   Status_info:  0
Changes (by ersts):
  * status:  new => assigned
Comment:
 It seems that the QgsVectorLayer.select() is not returning all the
 features when using its own extent. One possible solution is to simply use
 the extent of the map canvas. A second would be to add a hack to expand
 the extent a little, but that is not really a solution. The real solution
 to to fix the underlying vector class.
 I have filed a new ticket ( #2658 ) describing the vector layer problem
 and will keep this ticket open for the time being.
 In the mean time you can manually select all of you points then launch the
 event browser.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2621#comment:3>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
