[QGIS-trac] [Quantum GIS] #2670: assertion failure on libqgis
Quantum GIS
qgis at qgis.org
Thu Apr 22 07:25:01 EDT 2010
Reporter: orgads | Owner: nobody
Type: bug | Status: new
Priority: critical: causes crash or data corruption | Milestone: Version 1.5.0
Component: MapCanvas | Version: 1.4.0
Keywords: | Platform_version:
Platform: Debian | Must_fix: No
Status_info: 0 |
Hello,
I tried to run an application using libqgis, and I received the following
message:
/build/buildd/qgis-1.4.0/src/core/qgscoordinatereferencesystem.cpp:1268:
long int QgsCoordinateReferenceSystem::getRecordCount(): Assertion
`myResult == 0' failed.
I figured out that if ~/.qgis directory doesn't exist, this assertion
fails.
Looking at qgscoordinatereferencesystem.cpp:1268 I found a comment
regarding this situation:
myResult = sqlite3_open(
QgsApplication::qgisUserDbFilePath().toUtf8().data(), &myDatabase );
if ( myResult != SQLITE_OK )
QgsDebugMsg( QString( "Can't open database: %1" ).arg( sqlite3_errmsg(
myDatabase ) ) );
// XXX This will likely never happen since on open, sqlite creates the
// database if it does not exist.
assert( myResult == SQLITE_OK );
Well, apparently if the directory doesn't exist, sqlite doesn't create it.
It only creates the db file...
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2670>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
