[QGIS-trac] [Quantum GIS] #2673: Enhancements for georeferencer
    Quantum GIS
    qgis at qgis.org
    Fri Apr 23 04:33:37 EDT 2010
   Reporter:  mhugent                                    |              Owner:  mmassing
       Type:  patch                                      |             Status:  new
   Priority:  critical: causes crash or data corruption  |          Milestone:  Version 1.5.0
  Component:  Build/Install                              |            Version:  HEAD
   Keywords:                                             |   Platform_version:
   Platform:  All                                        |           Must_fix:  No
Status_info:  0                                          |
 This patch adds the following functionality to the georeferencer:
 - georef window can be docked / undocked (configure georeferencer dialog)
 - gcp items may show ids / coords / ids and coords
 - it is possible to print a pdf report after transformation that contains
 information about the parameters and the residuals
   (pdf icon in transformation settings)
 - for linear transformation, it is also possible to do warping (e.g. if
 resolution change is needed )
 - it adds the possibility to do helmert transformation with a world file.
 However, because QGIS is at the moment slow reading rasters with rotated
 world files, this possibility is disabled for helmert transformation at
 the moment
 Manuel, could you review the patch?
 cheers,
 Marco
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2673>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
