[QGIS-trac] [Quantum GIS] #2676: SPIT plugin - serial datatype instead of integer on primary key column
Quantum GIS qgis at qgis.org
Sat Apr 24 03:12:04 EDT 2010
   Reporter:  imincik1                          |              Owner:  timlinux
       Type:  enhancement                       |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.5.0
  Component:  C++ Plugins                       |            Version:  HEAD
   Keywords:  spit                              |   Platform_version:
   Platform:  All                               |           Must_fix:  No
Status_info:  0                                 |
 When exporting ESRI SHP to PostGIS using SPIT plugin, resulting PostGIS
 table is created with 'integer' data type on PRIMARY KEY column (gid)
 instead usual 'serial' data type.
 Such created table is not usable for clients expecting auto increment
 value on 'gid' column and it also differs from standard shp2pgsql tool.
 Example:
 1. Table created by SPIT:
 gid integer,
 foo character varying,
 the_geom geometry
 2. Expected table structure:
 gid serial,
 the_geom geometry
 Both of these cases are working well in QGIS. If there is no serious
 reason for
 'integer', I would suggest switching to 'serial' data type.
 Looking to source code, we need to:
 1. change 'integer' to 'serial' in table creation statement.
 2. change data INSERT statements to not include 'gid' column value.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2676>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
