[QGIS-trac] [Quantum GIS] #2687: Variable Snapping Marker Size
Quantum GIS
qgis at qgis.org
Fri Apr 30 16:16:11 EDT 2010
Reporter: sandinog | Owner: nobody
Type: enhancement | Status: new
Priority: minor: annoyance | Milestone: Version 1.5.0
Component: Digitising | Version: HEAD
Keywords: vertex, active feedback, snap confirmation | Platform_version:
Platform: Windows | Must_fix: No
Status_info: 0 |
I'd like to see vertex markers, if snapping is set to pixels, be a radius
of the number of pixels generally set or set for the layer being edited;
and if snapping is by scale distance, be a minimum of three pixels wide,
and as a maximum, the radius of the distance set for snapping. So, if
you're zoomed wide, the markers would be wide spots on the lines, and if
you're zoomed in close, particularly with vertices close together, you
could pick a spot where only the vertex you want to affect will be
selected.
It would also be nice if the circle could change color when the mouse is
within it, so you can tell that snapping is active, working, and your next
click will snap to the vertex you want to snap to, and not just where the
mouse click occurs, or the wrong vertex.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2687>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
