[QGIS-trac] Re: [Quantum GIS] #2923: QGIS 1.5 Tethys crashes when open the Fetch Python Plugins
Quantum GIS qgis at qgis.org
Tue Aug 3 07:15:40 EDT 2010
   Reporter:  mapasPT                                    |              Owner:  borysiasty
       Type:  bug                                        |             Status:  new
   Priority:  critical: causes crash or data corruption  |          Milestone:  Version 1.6.0
  Component:  Python plugins and bindings                |            Version:  1.5.0
   Keywords:  Fetch Python Plugins, Plugins Installer    |   Platform_version:  Seven
   Platform:  Windows                                    |           Must_fix:  No
Status_info:  0                                          |
Comment(by lutra):
 > The problem with the GDAL tools ara solved. I've reported that in the
 Forum.
 sorry, I do not have the time to follow both the trac and forum.
 > You have solved this problem in (others) machines?
 I don't remember exactly.
 Under linux it probably passed by removing the packages, all remaining
 qgis system files, the .qgis folder and the ~/.config/QuantumGIS/QGIS.conf
 file
 Under linux you may want ot try to reomve the c:\osgeo4w directory, all
 the shortcuts, the .qgis directory and then make a full scan of the
 registry (I use CCleaner) and fix problems.
 If I'm not wrong this worked but this doesn't mean that this is *the*
 solution for this problem.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2923#comment:9>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
