[QGIS-trac] [Quantum GIS] #2933: KML export: Field values are
shifted into <description> and <name>
Quantum GIS
qgis at qgis.org
Mon Aug 9 20:13:42 EDT 2010
#2933: KML export: Field values are shifted into <description> and <name>
Reporter: volter | Owner: nobody
Type: bug | Status: new
Priority: critical: causes crash or data corruption | Milestone: Version 1.6.0
Component: Data Provider | Version: Trunk
Keywords: | Platform_version:
Platform: All | Must_fix: No
Status_info: 0 |
Using QGIS' "Save Vector Layer as" produces undesired results. Whilst the
schema definition looks good, the first two columns' content is shoved
into <description> and <name>. You also run into data type problems
therefore. A random message from a mailing list claimed similar problems
and the writer was told, he used the API wrong. Sadly I couldn't figure
out, how to use it correctly!
I also converted with ogr2ogr and the output looks correct. But neither
file shows the correct attributes in QGIS. That might be related.
The included shapefile is the source of conversion. ogr.kml and qgis.kml
are the conversions.
GDAL version is 1.6.8.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2933>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
