[QGIS-trac] Re: [Quantum GIS] #2938: Add advance selection tools to
core
Quantum GIS
qgis at qgis.org
Thu Aug 19 00:30:12 EDT 2010
#2938: Add advance selection tools to core
Reporter: jpalmer | Owner: nobody
Type: patch | Status: reopened
Priority: major: does not work as expected | Milestone: Version 1.6.0
Component: MapCanvas | Version: Trunk
Resolution: | Keywords: maptool select
Platform_version: | Platform: All
Must_fix: No | Status_info: 0
Comment(by jpalmer):
Replying to [comment:6 timlinux]:
> For rotating point symbols, you edit a point layer, and then use the
symbol rotation tool to rotate the selected point to your specified angle.
Currently this does not work with the new selection tools.
I think you must be using the v2 renderer, because it works for me. Note
you don't even need to use the selection tools to use this maptool.
> I tried your patch above. The radio buttons would be better placed on
the map tools panel than the overlay panel.
hmm, weird in my compiled version using the patch under
win32/VC2008/QT4.5.2 it shows up in the map tools panel. See attached
image. I did notice a little text case bug in the default value for the
new option. I have now uploaded a new version.
> Also please note the issue with Alt clicking and dragging remains - alt
is not a usable modifier key for mouse click & drag actions on unix since
in most window managers it moves the entire window.
Note sure what to do here as there are no more modifier keys left as the
Shift and Ctrl keys are already in use. We could start allowing any
keyboard shortcut, but that could get messy with the user definable short-
cut actions already in place. Any ideas?
Cheers
Jeremy
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2938#comment:8>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
