[QGIS-trac] Re: [Quantum GIS] #2078: [Windows] adding a GRASS raster created with r.external crashes QGIS
Quantum GIS qgis at qgis.org
Fri Feb 5 12:21:12 EST 2010
        Reporter:  pcav                                       |         Owner:  rugginoso
            Type:  bug                                        |        Status:  new
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.5.0
       Component:  GRASS                                      |       Version:  HEAD
      Resolution:                                             |      Keywords:
Platform_version:                                             |      Platform:  Windows
        Must_fix:  No                                         |   Status_info:  0
Comment (by lutra):
 > landcover.img? Aren't we talking about GRASS? I am testing with gtopo30
 from demo mapset in alaska GRASS location from demo dataset.
 Yes, I'm just importing the image in a mapset with r.in. By the way is the
 same raster you find in mapset in the qgis demo dataset. By the way the
 results (for me) are the same when using directly the data inside the
 mapset of the qgis demo dataset.
 I'll try to do what you suggest and the report back.
 In any case as for you is working I would suggest to test some other
 windows installation, maybe are just mine that are giving problems.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2078#comment:12>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
