[QGIS-trac] Re: [Quantum GIS] #1945: [Vista] Qgis crashes removing GRASS raster layer from map canvas
Quantum GIS qgis at qgis.org
Fri Feb 5 19:39:31 EST 2010
        Reporter:  juanelz                                    |         Owner:  rugginoso
            Type:  bug                                        |        Status:  closed
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.5.0
       Component:  GRASS                                      |       Version:  HEAD
      Resolution:  fixed                                      |      Keywords:  GRASS rasters
Platform_version:  Vista                                      |      Platform:  Windows
        Must_fix:  Yes                                        |   Status_info:  0
Comment (by lutra):
 Replying to [comment:23 rblazek]:
 > It cannot be fixed in GRASS raster provider.
 > I can only recommend you to dont use valuetool with GRASS rasters (and
 probably WMS).
 Hi just checked qgis 1.4 and the "value tool" plugin works fine with GRASS
 rasters. You may want also to give a look to the attached images.
 With QGIS 1.4 I opened the GRASS mapset in the qgis sample dataset, loaded
 the raster (gtopo30) and changed its colormap with r.colors and closed the
 mapset.
 Then I reopened the mapset and the rasters with qgis 1.5 and this is how
 it shows (plus the value tool error).
 Tested under windows xp, but it should be the same also under linux.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1945#comment:25>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
