[QGIS-trac] Re: [Quantum GIS] #1945: [Vista] Qgis crashes removing GRASS raster layer from map canvas
Quantum GIS qgis at qgis.org
Sun Feb 7 05:57:39 EST 2010
        Reporter:  juanelz                                    |         Owner:  rugginoso
            Type:  bug                                        |        Status:  closed
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.5.0
       Component:  GRASS                                      |       Version:  HEAD
      Resolution:  fixed                                      |      Keywords:  GRASS rasters
Platform_version:  Vista                                      |      Platform:  Windows
        Must_fix:  Yes                                        |   Status_info:  0
Comment (by rblazek):
 Replying to [comment:28 lutra]:
 > a) On both XP and Vista when I import (v.in) the following raster
 (single band)
 > http://www.faunalia.it/qgis/data/srtm30-relief.zip
 > qgis always renders the image with the colors scrambled.
 > b) On both XP and Vista when I import (v.in) the following raster (multi
 band)
 > http://www.faunalia.it/qgis/data/landsat-mosaic-test.zip
 > qgis renders the image fine.
 I dont see any obvious difference which could cause it, apart there are 2
 rules in CT for srtm30.
 Its on you to find the difference causing the problem. Try various CT,
 pieces of raster etc.
 And please test first if it renders well in pure GRASS! Such a test should
 always be done before an error is reported for QGIS!
 > d) in all cases a) b) and c) if the "value tool" pluign is active it
 returns a python error. It used to work with GRASS rasters.
 Please DON'T report the problems with valuetool here. I have explained why
 the problem cannot be fixed in GRASS provider. You can fill a ticket for
 enhancement of raster providers infrastructure. You can fix the valuetool
 to use only raster layer identify().
 Just a note about tools like that, in the new GRASS provider I have
 followed GRASS philosophy to access GRASS data via modules, and that means
 everywhere identify() is called the GRASS module is run. That means, if
 you have a tool like valuetool and you move to mouse over QGIS canvas the
 GRASS module shoudl be called for each pixel, e.i. hundreds / thousands of
 time. Isn't nice?!
 > e) On both XP and Vista, when applying a r.colors rule on b) it works
 fine and it refreshes correctly. When applying a r.colors rule on c) it
 renders with colors scrambled.
 > Could this mean that there is a problem with single band images?
 What do you mean by single band and multi band? GRASS rasters are always
 single band.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1945#comment:29>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
