[QGIS-trac] [Quantum GIS] #2418: OGR layer converter errors
Quantum GIS qgis at qgis.org
Mon Feb 8 10:44:53 EST 2010
   Reporter:  nhopton                                    |              Owner:  timlinux
       Type:  bug                                        |             Status:  new
   Priority:  critical: causes crash or data corruption  |          Milestone:
  Component:  C++ Plugins                                |            Version:  HEAD
   Keywords:  OGR layer converter                        |   Platform_version:
   Platform:  Windows                                    |           Must_fix:  No
Status_info:  0                                          |
 QGIS 1.4, Vista 32-bit.
 Please see here for the background to this problem:
 http://forum.qgis.org/viewtopic.php?f=2&t=6123
 OGR layer converter - when used to convert an ESPG:27700 shapefile to KML
 errors of about 120 metres occur. The error is consistent with the layer
 converter not recognising the '+datum=OSGB36' parameter in the parameter
 string.
 In the attached zip: (1) 'Home.kml' a KML file for a line traced in Google
 Earth. (2) 'Home.shp', the result of loading the KML file into QGIS and
 saving it as a projected shape file. (3) 'homeconverted.kml', the result
 of using the layer converter to reconvert the the shape file to KML.
 I know that the shape file (2) is correct.
 Trying to make a GPX file from the shape file using the layer converter
 does not work.
 Regards,
 Nick.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2418>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
