[QGIS-trac] Re: [Quantum GIS] #2426: On-the-fly projection issues
with large extents
Quantum GIS
qgis at qgis.org
Tue Feb 9 18:30:36 EST 2010
#2426: On-the-fly projection issues with large extents
Reporter: gislab | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.5.0
Component: Projection Support | Version: HEAD
Resolution: | Keywords:
Platform_version: | Platform: All
Must_fix: No | Status_info: 0
Changes (by lutra):
* platform: Windows => All
Comment:
Well, you are right. I made a slightly different test:
The vector you posted is defined in wgs84 crs and I exported it with
"ftools" (I misunderstood your steps) to the system you describe, so I had
obviously no problems.
Now... your vector is geographically really wide(!), defined in a
geographic crs, and what you do is to reproject it in a projected crs.
Maybe the result cannot be the expected one, especially if/when the vector
crosses/nears the 180◦ longitude line? Really not sure.
[See also paragraph 5.2.6 of the qgis 1.3 user manual if you want to avoid
to see the features crossing the 180º lon line separated from the others]
Somehow related to #2349 ?
In any case if you need the vector in the projected crs you describe, and
the project in the same crs, an easy workaround is to export it to this
projection with ftools, instead of having qgis reproject it on the fly.
I'm not sure how arcview works, but I believe that gvsig (the only other
gis program I can test now) works like it, but actually I can't understand
its logic:
I created a view and defined its projection as the crs you describe, then
added to the view your vector "bnd-political-boundary-a". The vector shows
fine (and no zoom problems), the only "detail" is that is not reprojected.
It shows as in a wgs84 qgis project, but in the properties the vector crs
is the one of the view.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2426#comment:4>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
