[QGIS-trac] Re: [Quantum GIS] #2433: Fix relative paths from
absolute-with-symlinks
Quantum GIS
qgis at qgis.org
Fri Feb 12 07:44:33 EST 2010
#2433: Fix relative paths from absolute-with-symlinks
Reporter: strk | Owner: nobody
Type: patch | Status: new
Priority: minor: annoyance | Milestone: Version 1.5.0
Component: Project Loading / Saving | Version: HEAD
Resolution: | Keywords:
Platform_version: | Platform: Debian
Must_fix: No | Status_info: 1
Comment (by jef):
Replying to [comment:2 strk]:
> Replying to [comment:1 jef]:
> > What's the point in using two different paths to the same directory in
one project?
> No point. It was qgis doing that, I just used the "browse" dialog to
select
> the files, and maybe I started it from my home directory so had to go
find
> the files somewhere.
I don't understand. Didn't you use two different paths to the same
directory and QGIS merily didn't notice or care, that there was a symlink
involved?
> I'm trying hard but I can't figure a reason why a user would ever want
to get that
> behaviour. I would really expect it to "just work".
I does just work, doesn't it? It's just that the paths in the project
file aren't the one you expected.
> I would rather get a warning popup if a filename in the project file
can't be found.
> After all you can't guarantee you'll produce a project file that will
work if you
> can't find the files.
I was not implying that anything can't be found. For GRASS rasters the
"filename" isn't actually a path to a file. The referred information is
in multiple files in the directories within the GRASS mapset. The path to
the mapset is still valid, existing and can be expresses relatively to the
project file.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2433#comment:3>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
