[QGIS-trac] [Quantum GIS] #2440: new GRASS raster provider and QGIS
raster layer properties: changes needed
Quantum GIS
qgis at qgis.org
Fri Feb 12 13:13:38 EST 2010
#2440: new GRASS raster provider and QGIS raster layer properties: changes needed
Reporter: lutra | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.5.0
Component: Data Provider | Version: HEAD
Keywords: | Platform_version:
Platform: All | Must_fix: Yes
Status_info: 0 |
The new GRASS provider solved many problems, especially a few nasty bugs
that made many GRASS modules not usable under Vista and Seven (caused qgis
to crash). See for example #1945 and #2028
Moreover it "solved" a qgis critical bug that was not yet spotted:
basically after closing a mapset (and leaving a GRASS layer in the
legend), if click on the canvas with a tool such the identify qgis
crashes. You can test this bug in qgis 1.4.
Nevertheless there are a few consequences in the qgis raster layer
properties that would need a fix (in the provider or in the properties or
maybe both).
The synptoms I see are:
A) making GRASS raster pixels transparent (properties -> transparency)
does not work anymore.
B) changing the colormap (freakout, pseudocolor, colormap) does not work
anymore.
C) if you tested A) and/or B) you probably already noticed that now, in
the qgis raster layer properties, the "render as" property (and the below
"RGB more..." or "Single Band Properties") are messed:
*) GRASS raster should always open as "single band gray" and the "three
band color" should be greyed out and not available. In trunk the "render
as" property for GRASS rasters shows by default the "three band color"
selected (that does not make sense). You can then choose "single band
gray", close the properties and then if you'll open it again "three band
color" will show correctly greyed out.
*) Even when you manually choose "single band gray", the "gray band"
dropdown is not populated (should show two options "band1" and "not set")
and the "color map" dropdown does not show the correct otion.
*) The colormap is never shown in the appropriate tab.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2440>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
