[QGIS-trac] Re: [Quantum GIS] #2444: Discrepancy between gdalinfo
and QGIS raster metadata
Quantum GIS
qgis at qgis.org
Mon Feb 15 09:20:54 EST 2010
#2444: Discrepancy between gdalinfo and QGIS raster metadata
Reporter: alobo | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.5.0
Component: Rasters | Version: HEAD
Resolution: | Keywords:
Platform_version: | Platform: Debian
Must_fix: No | Status_info: 1
Comment (by rbivand):
Replying to [comment:2 mmassing]:
> To summarize this more concisely, I think this is a bug in R (which
fails to handle general
> coordinate systems), and probably can be worked around by reprojecting
the problematic file to a north-up orientation.
No, in no way. The R rgdal package interfaces GDAL, and the GDAL driver
sees the file in exactly the same way. If the origin is NW, but the
resolution increment is positive, as here, any application using the
information GDAL has will behave in the same way. No jumping through hoops
here, the problem must be in QGIS and/or the plugin writing the file with
inappropriate parameters. I'm not planning to make any changes in the
R/GDAL interface to suit a very odd case. If the data were correctly saved
and described, GDAL would see them correctly. Maybe the GDAL driver might
accommodate oddities, but at out end, we can't make adjustments for one
application.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2444#comment:5>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
