[QGIS-trac] Re: [Quantum GIS] #2444: Discrepancy between gdalinfo and QGIS raster metadata
Quantum GIS qgis at qgis.org
Wed Feb 17 11:45:39 EST 2010
        Reporter:  alobo                             |         Owner:  nobody
            Type:  bug                               |        Status:  new
        Priority:  major: does not work as expected  |     Milestone:  Version 1.5.0
       Component:  Rasters                           |       Version:  HEAD
      Resolution:                                    |      Keywords:
Platform_version:                                    |      Platform:  Debian
        Must_fix:  No                                |   Status_info:  1
Comment (by alobo):
 ok, I think I've been able to clarify this:
 1. Interpolation plugin generates an Arc Ascii raster, even if it's named
 test2.tif
 2. This file has the correct orientation once imported in R through either
 readGDAL()
 or raster()
 3. But lacks projection information: no projection information is
 displayed by gdalinfo,
 both through GDALinfo() and through Raster/Information in QGIS gdal
 plugin.
 4. Then I used QGIS Raster/Assign projection to assign UTM31N ED50.  The
 projection
 is assigned and the file converted to geotiff (without asking you)
 5. The new test2.tif shows correct projection information but is reversed
 once imported in R.
 So the problem is in Raster/Assign projection. I still have to check if
 this happens with
 any Raster/ utility in QGIS, hope not.
 Agus
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2444#comment:10>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
