[QGIS-trac] [Quantum GIS] #2457: qgis (1.4,
trunk) crashes if reprojecting with a raster active in the legend
Quantum GIS
qgis at qgis.org
Sun Feb 21 14:31:10 EST 2010
#2457: qgis (1.4, trunk) crashes if reprojecting with a raster active in the
legend
Reporter: lutra | Owner: nobody
Type: bug | Status: new
Priority: critical: causes crash or data corruption | Milestone: Version 1.5.0
Component: Projection Support | Version: HEAD
Keywords: | Platform_version:
Platform: All | Must_fix: Yes
Status_info: 0 |
The following has been tested with data from the QGIS sample dataset (plus
the small shapefile attached to this ticket) but also with data from other
geographic regions/projections.
When the problem occurs qgis freezes, starts to eat memory/cpu and
eventually crashes (in the 1.4 version the crash is immediate). It has
been proved on ubuntu 9.04, 9.10, Debian testing and Windows XP.
[[BR]]
[[BR]]
Steps:
*) add the "alaska.shp" shapefile from the qgis sample dataset.
*) set the project crs as the one of the above vector, EPSG:2964 and
'''enable''' on the fly reprojection
*) add the "landcover.img" raster from the qgis sample dataset (it is
defined in the the EPSG:2964 crs)
*) add to the project the attached shapefile ("alaska_clipped.shp"): it
was obtained by clipping the Alaska region from the "world borders"
shapefile, that is defined in the WGS84 crs (EPSG:4326)
everything align OK, because the last vector is correctly reprojected in
the EPSG:2964 coordinate system
*) uncheck from the legend the raster layer
*) go in the project properties and change the project crs from EPSG:2964
to EPSG:4326
*) at this stage the two vectors still align perfectly as the first one is
reprojected in the EPSG:4326 coordinate system
*) now check the raster layer in the legend (I KNOW THAT WON'T BE
REPROJECTED IN ANY CASE): qgis freezes, starts to eat memory/cpu and
eventually crashes
[[BR]]
[[BR]]
The counter test '''DOES NOT CAUSE''' qgis to crash. Steps:
[[BR]]
*) Use the gdal_warp utility to reproject the "landcover.img" raster from
EPSG:2964 to EPSG:4326
*) Add the obtained raster to a new project defined in the EPSG:4326
coordinate system and enable on the fly reprojection
*) add the attached shapefile ("alaska_clipped.shp")
*) add the shapefile "alaska.shp" from the qgis sample dataset
*) go in the project properties and change the project crs from EPSG:4326
to EPSG:2964
reprojected in the EPSG:2964 coordinate system
REPROJECTED IN ANY CASE): qgis does not freeze nor crash, it simple does
not show the raster as expected.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2457>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
