[QGIS-trac] Re: [Quantum GIS] #2271: print composer large format A0
Quantum GIS qgis at qgis.org
Fri Jan 8 04:59:16 EST 2010
        Reporter:  gespiel                           |         Owner:  ersts
            Type:  patch                             |        Status:  new
        Priority:  major: does not work as expected  |     Milestone:  Version 1.5.0
       Component:  Printing                          |       Version:  1.3.0
      Resolution:                                    |      Keywords:
Platform_version:  XP sp3                            |      Platform:  Windows
        Must_fix:  Yes                               |   Status_info:  0
Comment (by mhugent):
 Hi gespiel
 Did you work with or without the patch applied?
 If without patch: I think it is because current svn version keeps all the
 image data in virtual memory.
 Also: instead of using the PDF printer, you could use the (platform
 independent) pdf export in composer. Maybe the results are better
 reprocable on other systems like that.
 Marco
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2271#comment:15>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
