[QGIS-trac] [Quantum GIS] #2867: Label rotation in composer
Quantum GIS qgis at qgis.org
Tue Jul 6 11:18:29 EDT 2010
   Reporter:  medspx            |              Owner:  nobody
       Type:  bug               |             Status:  new
   Priority:  minor: annoyance  |          Milestone:  Version 1.6.0
  Component:  Printing          |            Version:
   Keywords:                    |   Platform_version:
   Platform:  All               |           Must_fix:  No
Status_info:  0                 |
 One new feature that would be good is the support of label rotation in the
 composer.
 For the moment you can rotate pictures and shapes when you compose a map !
 But you can't do this with labels...
 If you look into .qpt files (QGis Composer Template files), you can see
 that the label definition has got a rotation attribute. If you try to
 modify it directly in the file, it does nothing: the label is still
 displayed with no rotation.
 Here is an extract from a .qpt file:
 <ComposerLabel labelText="TITRE" margin="0">
   <LabelFont description="DejaVu Sans,18,-1,5,75,0,0,0,0,0"/>
   <FontColor red="0" blue="0" green="0"/>
   <ComposerItem width="25.49839762376757" x="390.5356783919598"
 y="13.11658291457286" rotation="0" height="11.22057304872989"
 frame="false" outlineWidth="0" zValue="1"
 lastValidViewScaleFactor="1.98812351543943" positionLock="false">
    <FrameColor alpha="255" red="0" blue="0" green="0"/>
    <BackgroundColor alpha="255" red="255" blue="255" green="255"/>
   </ComposerItem>
  </ComposerLabel>
 As you can see, the rotation attribute value of the ComposerItem is fixed
 to 0. If you change it manually, it does nothing.
 As it is already coded in the .qpt "vocabulary", I guess that it could be
 possible to use this attribute to support label rotation. Then, IMHO, I
 think that we can focus on building a rotation routine in the composer
 code that use this attribute...
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2867>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
