[QGIS-trac] Re: [Quantum GIS] #2772: gpx files show only points not lines
Quantum GIS qgis at qgis.org
Mon Jul 19 15:12:36 EDT 2010
        Reporter:  ScottParker                       |         Owner:  gjm
            Type:  bug                               |        Status:  closed
        Priority:  major: does not work as expected  |     Milestone:  Version 1.5.0
       Component:  Vectors                           |       Version:  Trunk
      Resolution:  fixed                             |      Keywords:  gpx drag drop load waypoints tracks
Platform_version:                                    |      Platform:  OS X
        Must_fix:  No                                |   Status_info:  0
Changes (by gjm):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 The problem with drops of gpx files not showing the 'select a sublayer'
 box has been fixed in r13939.
 The cause was that drops were being treated the same a passing the
 filename in on the command line, which wasn't setup to ask the user for
 input.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2772#comment:6>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
