[QGIS-trac] Re: [Quantum GIS] #2911: Enable the query builder for
view that don't have unique id
Quantum GIS
qgis at qgis.org
Wed Jul 28 15:34:14 EDT 2010
#2911: Enable the query builder for view that don't have unique id
Reporter: pinux | Owner: nobody
Type: bug | Status: reopened
Priority: major: does not work as expected | Milestone: Version 1.6.0
Component: Data Provider | Version: Trunk
Resolution: | Keywords: Postgis, Query Builder, View
Platform_version: | Platform: Windows
Must_fix: No | Status_info: 0
Changes (by pinux):
* status: closed => reopened
* resolution: wontfix =>
Comment:
I have already found a workaround. But, if I can add the Sql statement
under the Sql column in the "Add to Postgis table(s)" and open it in qgis
I don't see why it should not be possible to open the Query builder and do
it in a much easier way.
Or if it should not be possible to add a query on a view that don't have
unique id (like you suggest), it should not be possible to add the query
directly under the Sql column, like it is possible now.
If you think that it don't make sense, close again.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2911#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
