[QGIS-trac] Re: [Quantum GIS] #2598: Polygon fill patterns scale differently in pdf export as raster versus non-raster
Quantum GIS qgis at qgis.org
Mon Jun 7 10:11:54 EDT 2010
raster
        Reporter:  jctull                            |         Owner:  mhugent
            Type:  bug                               |        Status:  closed
        Priority:  major: does not work as expected  |     Milestone:  Version 1.5.0
       Component:  Printing                          |       Version:  HEAD
      Resolution:  wontfix                           |      Keywords:  composer pdf export raster vector
Platform_version:  10.6.2                            |      Platform:  OS X
        Must_fix:  No                                |   Status_info:  0
Changes (by mhugent):
  * status:  new => closed
  * resolution:  => wontfix
Comment:
 This is a Qt but (http://bugreports.qt.nokia.com/browse/QTBUG-5114). It
 works if you print to raster because QPainter then renders to image first
 and then embedds the image into the pdf.
 No idea why the patch in the ticket is not applied to the qt sources. I
 tested with a patched Qt and it worked properly.
 And note: it only works for symbology-ng 'svgFill' types. The hardcoded
 polygon fill hatches are printed as raster by QBrush, so won't scale
 nicely on printout.
 Closing the ticket because it is not a bug in QGIS (though I understand it
 is annoying for users).
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2598#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
