[QGIS-trac] Re: [Quantum GIS] #192: Map composer needs a north arrow
Quantum GIS qgis at qgis.org
Sat Jun 12 16:36:49 EDT 2010
        Reporter:  g_j_m             |         Owner:  mhugent
            Type:  enhancement       |        Status:  closed
        Priority:  minor: annoyance  |     Milestone:  Version 1.6.0
       Component:  Printing          |       Version:  HEAD
      Resolution:  invalid           |      Keywords:
Platform_version:                    |      Platform:  All
        Must_fix:  No                |   Status_info:  0
Changes (by mhugent):
  * status:  reopened => closed
  * resolution:  => invalid
Comment:
 The point is that, in the print composer, you can rotate a composer map.
 After that, north is up in the main map window, but not in the rotated
 composer map (sync from map refers to the composer map. If there are
 several ones in the composer, you may select which one).
 In your case, as you don't rotate the composer map, it is probably best to
 just rotate the picture 'by hand'.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/192#comment:15>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
