[QGIS-trac] Re: [Quantum GIS] #2330: Loading missing layer (shapefile) requires changing the "Files of type" setting (was: Loading missing layer masks shapefiles in dialog with extraneous information)
Quantum GIS qgis at qgis.org
Sun Jun 13 17:38:14 EDT 2010
setting
   Reporter:  jctull                                |              Owner:  nobody
       Type:  bug                                   |             Status:  new
   Priority:  major: does not work as expected      |          Milestone:  Version 1.6.0
  Component:  Project Loading / Saving              |            Version:  HEAD
   Keywords:  missing layer shapefile layerid load  |   Platform_version:  10.6.2
   Platform:  OS X                                  |           Must_fix:  No
Status_info:  0                                     |
Comment(by jctull):
 This is still a problem. I tried for a better title also.
 The open file dialog populates the "Files of type" field with something
 like "my_shapefile.shp|layerid=0". Instead, it should only have the
 "my_shapefile.shp" without the layerid information. As a consequence, you
 have to change the "files of type" field every time you encounter a
 missing shapefile warning.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2330#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
