[QGIS-trac] R: QGIS-trac Digest, Vol 50, Issue 62
Massimo Di Stefano massimodisasha at yahoo.it
Mon Jun 14 07:11:27 EDT 2010
Have you  a fix for it,
or can you point us to the needed changes (which file/line) or suggestion to debug it ?
SDA4PP plug-in is affected by the same problem.
Thanks.
Changed 56 seconds ago by lutra status changed from new to closedresolution set to invalidit is also a 3rd party plugin so in any case the problems need to be reported in the qgis-dev mailing list.
Message: 9
Date: Sat, 12 Jun 2010 14:42:30 -0000
Subject: [QGIS-trac] Re: [Quantum GIS] #2803: manageR don't works on
    OSX
Cc: qgis-trac at lists.osgeo.org
Message-ID: <044.bc3c12e95a905a51c04409d2a5dc7e49 at qgis.org>
Content-Type: text/plain; charset="utf-8"
#2803: manageR don't works on OSX
   Reporter:  epifanio                          |              Owner:  borysiasty
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.5.0
  Component:  Python plugins and bindings       |            Version:  HEAD
   Keywords:  R , rpy2, manageR                 |   Platform_version:  osx
   Platform:  OS X                              |           Must_fix:  No
Status_info:  0                                 |
Comment(by pcav):
 It should be the usual problem with paths.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2803#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS,
URL: http://lists.osgeo.org/pipermail/qgis-trac/attachments/20100614/9f23642a/attachment.html
More information about the QGIS-trac mailing list
