[QGIS-trac] Re: [Quantum GIS] #2819: Copied record field mismatch
from shapefile to postgis
Quantum GIS
qgis at qgis.org
Fri Jun 18 05:29:09 EDT 2010
#2819: Copied record field mismatch from shapefile to postgis
Reporter: bonzai | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.5.0
Component: Data Provider | Version: 1.4.0
Keywords: | Platform_version:
Platform: Gentoo | Must_fix: No
Status_info: 1 |
Comment(by bonzai):
Replying to [comment:1 jef]:
> The field values are assigned in order not by name. Does the attribute
order in your postgis table match the order of fields in the shapefile's
dbf?
Looking in layers' properties attribute tab I've found this:
SHAPEFILE[[BR]]
-|id|name[[BR]]
1|0 |app_id[[BR]]
2|1 |su_id[[BR]]
3|2 |su <-------[[BR]]
4|3 |phase[[BR]]
5|4 |date[[BR]]
POSTGIS[[BR]]
-|id|name[[BR]]
1|0 |app_id[[BR]]
2|2 |su_id[[BR]]
3|3 |su <-------[[BR]]
4|4 |phase[[BR]]
5|5 |date[[BR]]
So it seems thats records have the same order but different ids.
A further information that could you help: the shapefile is the result of
'Export as shapefile' QGIS command.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2819#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
