[QGIS-trac] Re: [Quantum GIS] #2837: (linux) merge shapefiles
crashes qgis
Quantum GIS
qgis at qgis.org
Sun Jun 27 12:47:14 EDT 2010
#2837: (linux) merge shapefiles crashes qgis
Reporter: lutra | Owner: cfarmer
Type: bug | Status: new
Priority: critical: causes crash or data corruption | Milestone: Version 1.5.0
Component: Python plugins and bindings | Version: HEAD
Keywords: | Platform_version:
Platform: Debian | Must_fix: No
Status_info: 0 |
Changes (by alexbruy):
* cc: alexbruy (added)
Comment:
Confirmed QGIS crash on Slackware linux. Under Windows XP merging the
following files works fine.
But on Linux QGIS craches too when I try to open shapefile pen_01.shp.
Here is debug output before crash
Debug: /home/alex/devel/cpp/qgis/trunk/src/core/qgsmaprenderer.cpp: 186:
(adjustExtentToSize) -24040.6198250000015832,40992.8055770874052541 :
-22359.4931749999996100,41256.3346206665009959
Debug: /home/alex/devel/cpp/qgis/trunk/src/core/qgsscalecalculator.cpp:
139: (calculateGeographicDistance) Distance across map extent (m):
1.13268e+07
90: (calculate) Using conversionFactor of 39.3701
Debug: /home/alex/devel/cpp/qgis/trunk/src/core/qgsmaprenderer.cpp: 197:
(adjustExtentToSize) Scale (assuming meters as map units) = 1:8.82862e+07
Debug: /home/alex/devel/cpp/qgis/trunk/src/gui/qgsmapoverviewcanvas.cpp:
162: (drawExtentRect) panning: extent to widget: [-2147483648,-2147483648]
[1x1]
Debug: /home/alex/devel/cpp/qgis/trunk/src/core/qgsmaprenderer.cpp: 212:
(render) ========== Rendering ==========
Debug: /home/alex/devel/cpp/qgis/trunk/src/core/qgsmaprenderer.cpp: 236:
(render) Starting to render layer stack.
Debug: /home/alex/devel/cpp/qgis/trunk/src/core/qgsmaprenderer.cpp: 323:
(render) Rendering at layer item pen_0120100627193701245
Debug: /home/alex/devel/cpp/qgis/trunk/src/core/qgsmaprenderer.cpp: 331:
(render) If there is a QPaintEngine error here, it is caused by an emit
call
Debug: /home/alex/devel/cpp/qgis/trunk/src/core/qgsmaprenderer.cpp: 342:
(render) Rendering layer pen_01
Debug: /home/alex/devel/cpp/qgis/trunk/src/core/qgsmaprenderer.cpp: 343:
(render) Layer minscale 0
Debug: /home/alex/devel/cpp/qgis/trunk/src/core/qgsmaprenderer.cpp: 344:
(render) Layer maxscale 1e+08
Debug: /home/alex/devel/cpp/qgis/trunk/src/core/qgsmaprenderer.cpp: 345:
(render) Scale dep. visibility enabled? 0
Debug: /home/alex/devel/cpp/qgis/trunk/src/core/qgsmaprenderer.cpp: 346:
(render) Input extent: -24000.5930000000007567,40999.0800781250000000 :
-22399.5200000000004366,41250.0601196289062500
Debug:
/home/alex/devel/cpp/qgis/trunk/src/providers/ogr/qgsogrprovider.cpp: 586:
(select) Setting spatial filter using POLYGON((-24040.61982500
40341.74243660, -24040.61982500 41907.39776115, -22359.49317500
41907.39776115, -22359.49317500 40341.74243660, -24040.61982500
40341.74243660))
ERROR 1: Corrupted .shp file : shape 3 : panPartStart[4] = 10,
panPartStart[3] = 229
Segmentation fault
Running ogrinfo on this shape produces
bash-3.1$ ogrinfo ~/samples/vector/cart_2/pen_01.shp
INFO: Open of `/home/alex/samples/vector/cart_2/pen_01.shp'
using driver `ESRI Shapefile' successful.
1: pen_01 (Line String)
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2837#comment:6>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
