[QGIS-trac] Re: [Quantum GIS] #2391: Layer properties dialog and
Unique Value: cannot see which bitmap is used
Quantum GIS
qgis at qgis.org
Mon Jun 28 08:19:12 EDT 2010
#2391: Layer properties dialog and Unique Value: cannot see which bitmap is used
Reporter: trapanator | Owner:
Type: bug | Status: reopened
Priority: major: does not work as expected | Milestone: Version 1.5.0
Component: Symbology | Version: Trunk
Resolution: | Keywords:
Platform_version: | Platform: All
Must_fix: Yes | Status_info: 0
Changes (by trapanator):
* status: closed => reopened
* resolution: worksforme =>
Comment:
Sorry for my late response.
It still doesn't work in latest trunk:
1. load a point shapefile
1. open the layer properties and open symbology (use the old symbology)
1. select "Unique values"
1. get two values and assign different symbol to them
close the dialog box and reopen the layer properties. When you select the
two values on the list, the corresponding symbol on "Point Symbol" box is
not selected.
For me it is a usability bug, you can fix it in 1.6.0 if you want.
See the attachments.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2391#comment:5>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
