[QGIS-trac] Re: [Quantum GIS] #2845: QGIS won't compile with python
Quantum GIS qgis at qgis.org
Tue Jun 29 03:31:39 EDT 2010
   Reporter:  Alexbit                           |              Owner:  borysiasty
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:
  Component:  Python plugins and bindings       |            Version:
   Keywords:  python bindings                   |   Platform_version:  Linux
   Platform:  Linux                             |           Must_fix:  No
Status_info:  1                                 |
Comment(by Alexbit):
 If it's usefull for you:
 This is the output of ccmake for stable (1.0.x):
 The C compiler identification is GNU
 The CXX compiler identification is GNU
 Check for working C compiler: /usr/bin/gcc
 Check for working C compiler: /usr/bin/gcc -- works
 Detecting C compiler ABI info
 Detecting C compiler ABI info - done
 Check for working CXX compiler: /usr/bin/c++
 Check for working CXX compiler: /usr/bin/c++ -- works
 Detecting CXX compiler ABI info
 Detecting CXX compiler ABI info - done
 Found Proj: /usr/lib/libproj.so
 Found Sqlite3: /usr/lib/libsqlite3.so
 Found GEOS: /usr/lib/libgeos_c.so
 Found GDAL: /usr/lib/libgdal.so
 Found PostgreSQL: /usr/lib/libpq.so
 Found Expat: /usr/lib/libexpat.so
 Using GSL from /usr
 Could not find GRASS
 Found PythonLibs: /usr/lib/libpython2.6.so
 Found PythonInterp: /usr/bin/python2.6
 Python libraries found
 SIP is required in version 4.7 or later!
 Python bindings disabled due dependency problems!
 Looking for Q_WS_X11
 Looking for Q_WS_X11 - found
 Looking for Q_WS_WIN
 Looking for Q_WS_WIN - not found.
 Looking for Q_WS_QWS
 Looking for Q_WS_QWS - not found.
 Looking for Q_WS_MAC
 Looking for Q_WS_MAC - not found.
 Found Qt-Version 4.6.3 (using /usr/bin/qmake)
 Found OpenSSL: /usr/lib/libssl.so;/usr/lib/libcrypto.so
 Looking for _POSIX_TIMERS
 Looking for _POSIX_TIMERS - found
 Python not being built
 Configuring done
 This is the output of ccmake for develop (1.4.x)
 Looking for openpty
 Looking for openpty - not found
 Looking for openpty
 Looking for openpty - found
 Using GSL from /usr
 Configuring done
 This is the output of ccmake for SVN (1.5.x):
 Quantum GIS version: 1.5.0 Tethys (10500)
 Looking for openpty
 Looking for openpty
 Using GSL from /usr
 Found Python executable: /usr/bin/python2.6
 Found Python version: 2.6.5
 Found Python library: /usr/lib/libpython2.6.so
 Found SIP version: 4.10.2
 Found PyQt4 version: 4.7.3
 Configuring done
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2845#comment:3>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
