[QGIS-trac] Re: [Quantum GIS] #2845: QGIS won't compile with python
Quantum GIS qgis at qgis.org
Tue Jun 29 07:05:07 EDT 2010
        Reporter:  Alexbit                           |         Owner:  borysiasty
            Type:  bug                               |        Status:  closed
        Priority:  major: does not work as expected  |     Milestone:
       Component:  Python plugins and bindings       |       Version:
      Resolution:  duplicate                         |      Keywords:  python bindings
Platform_version:  Linux                             |      Platform:  Linux
        Must_fix:  No                                |   Status_info:  1
Changes (by jef):
  * status:  new => closed
  * resolution:  => duplicate
Comment:
 Replying to [comment:5 Alexbit]:
 > I'm sorry but, probably, I was not clear in the exposition of the
 problem.
 Ah ok, I didn't get it.  So this is a duplicate of #2678.
 Try this patch:
 --- qgis-1.4.0.orig/cmake/Python.cmake
 +++ qgis-1.4.0/cmake/Python.cmake
 @@ -148,12 +148,12 @@
      IF (HAVE_SIP_MODULE AND SIP_BINARY_PATH AND SIP_INCLUDE_DIR)
        # check for SIP version
        # minimal version is 4.7 (to support universal builds)
 -      SET (SIP_MIN_VERSION 040700)
 -      TRY_RUN_PYTHON (RES "import sip\nprint '%x' % sip.SIP_VERSION"
 SIP_VERSION)
 +      SET (SIP_MIN_VERSION 263936) # 0x40700
 +      TRY_RUN_PYTHON (RES "import sip\nprint '%d' % sip.SIP_VERSION"
 SIP_VERSION)
        IF (SIP_VERSION EQUAL "${SIP_MIN_VERSION}" OR SIP_VERSION GREATER
 "${SIP_MIN_VERSION}")
          SET (SIP_IS_GOOD TRUE)
        ENDIF (SIP_VERSION EQUAL "${SIP_MIN_VERSION}" OR SIP_VERSION
 GREATER "${SIP_MIN_VERSION}")
        IF (NOT SIP_IS_GOOD)
          MESSAGE (STATUS "SIP is required in version 4.7 or later!")
        ENDIF (NOT SIP_IS_GOOD)
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2845#comment:6>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
