[QGIS-trac] [Quantum GIS] #2486: Unique value symbology doesn't
work in canvas with postgres "character" data type
Quantum GIS
qgis at qgis.org
Wed Mar 3 11:10:00 EST 2010
#2486: Unique value symbology doesn't work in canvas with postgres "character"
data type
Reporter: mwtoews | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.5.0
Component: Symbology | Version: HEAD
Keywords: | Platform_version:
Platform: Windows | Must_fix: No
Status_info: 0 |
If a unique value symbology is applied to a PostGIS layer with a data type
"character", it can be formatted normally in the layer properties dialog
with expected results in the "Layers" pane. However, the lines are not
formatted in the map canvas as expected, as all lines use the "default"
(blank) classification.
A possible cause of the problem is that the data type "character" will pad
spaces to the specified width, for example "food" stored in character(5)
will actually be "food ", having a trailing space to fit 5 characters.
As a workaround, change the postgres data type in problem columns to
"character varying", if possible.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2486>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
