[QGIS-trac] [Quantum GIS] #2487: Memory data provider should not be
saved
Quantum GIS
qgis at qgis.org
Wed Mar 3 12:41:25 EST 2010
#2487: Memory data provider should not be saved
Reporter: ccrook | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.5.0
Component: Build/Install | Version: HEAD
Keywords: | Platform_version:
Platform: All | Must_fix: No
Status_info: 0 |
Layers built with the memory data provider should not be saved to the
project file, as when the file is reloaded, the data for the layers is no
longer available. This means that reloading the project does not restore
it to its saved state.
I think that when Quantum saves a project then it should check for in
memory layers, and provide the option of saving them to a persistent
provider, or removing them from the project.
Also it would good when an in memory layer is saved to a shapefile (or
other persistent provider) from the legend right click menu if the layer
was replaced with the saved layer. This make it much easier to make in
memory layers persistent in the project. At the moment I think you need
to save the layer, then load the saved version, and then remove the in
memory layer.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2487>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
