[QGIS-trac] [Quantum GIS] #2534: avoid the possibility to enter -in
attributes table- strings/numbers beyond the field length
Quantum GIS
qgis at qgis.org
Mon Mar 8 09:13:56 EST 2010
#2534: avoid the possibility to enter -in attributes table- strings/numbers beyond
the field length
Reporter: lutra | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.5.0
Component: Vectors | Version: HEAD
Keywords: | Platform_version:
Platform: All | Must_fix: Yes
Status_info: 0 |
Actually you can enter values in the attributes table with a length that
is > of the field length. This can be source of problems as a users can be
mislead to believe the field has room for more chars/numbers than has
really.
Fixing this will also indirectly fix another bug:
if the attributes table has only one row and you edit it, if you enter a
value that has more chars/numbers than allowed by the field length, when
you toggle editing to save changes, the value is not immediately truncated
leading to believe that that particular edit went fine.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2534>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
