[QGIS-trac] [Quantum GIS] #2542: field calculator default behaviour
Quantum GIS
qgis at qgis.org
Thu Mar 11 03:44:26 EST 2010
Reporter: best | Owner: nobody
Type: enhancement | Status: new
Priority: minor: annoyance | Milestone: Version 1.5.0
Component: Vectors | Version: 1.4.0
Keywords: field calculator | Platform_version:
Platform: All | Must_fix: No
Status_info: 0 |
Thank you for the field calculator it is a very welcome feature!
However its default behaviour (checkbox settings) is to update '''all'''
records in the first '''existing''' field. This applies to QGIS 1.4.0-2.8
(OpenSuse).[[BR]]
To prevent users from corrupting their data I would expect it the other
way round: update only selected records and ask for a new field.
== Explanation ==
* Most of the time I am using the field calculator, I want to update only
selected records (graphical or logical selection). So I have to take extra
care to check ''only update selected features''. When I forget to do so,
my data already being in the target field are gone. On the other hand if I
want to update all records and the default would be ''only update selected
features'' all I have to do is redoing the calculation after unchecking
''only update selected features''.[[BR]]
* The first existing field normally is an ID field. You do not want to
update this field! But if you do not take extra care you do so. If
''update existing field'' would be unchecked the user has to do something
in order to execute the calcualtion: either check ''update existing
field'' and choose the field or enter a new field. Thus the risk of data
corruption by accident is minimized.[[BR]]
I am totally aware that discarding the changes keeps the data as they are.
But it is annoying to stop the edit mode, discard all(!) changes and redo
all I did when I realize I made a mistake (if I realize!).
== Proposal ==
* If a selection exists on the table check ''only update selected
features'' by default.
* Uncheck ''update exisiting field'' by default.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2542>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
