[QGIS-trac] [Quantum GIS] #2588: Custom CRS sqlite3 query error
Quantum GIS
qgis at qgis.org
Wed Mar 24 19:08:35 EDT 2010
Reporter: sowelu | Owner: nobody
Type: patch | Status: new
Priority: major: does not work as expected | Milestone: Version 1.5.0
Component: Projection Support | Version: HEAD
Keywords: | Platform_version: Kubuntu 9.10
Platform: Debian | Must_fix: Yes
Status_info: 0 |
There is an error in the sqlite3 query that selects custom CRS from
qgis.db. The query tries to get the auth_id and auth_name fields, which
don't exist. It doesn't query the epsg field, which does exist. Note that
the insert queries for tbl_srs don't affect any of these fields.
As a result, if you set your map canvas or layer to a custom crs it
doesn't make it into the project file. Also, the dialogs don't have the
correct default custom crs set when you open them.
This patch removes the auth_id & auth_name fields and puts in the epsg
field. It works on Kubuntu 9.10, QGIS trunk r13139.
Alternatively, the database structure could be in error.
Cheers,
Roland
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2588>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
