[QGIS-trac] [Quantum GIS] #2602: (new) coordinate system selector
issues
Quantum GIS
qgis at qgis.org
Sun Mar 28 14:00:32 EDT 2010
#2602: (new) coordinate system selector issues
Reporter: lutra | Owner: nobody
Type: bug | Status: new
Priority: minor: annoyance | Milestone: Version 1.5.0
Component: Projection Support | Version: HEAD
Keywords: | Platform_version:
Platform: All | Must_fix: Yes
Status_info: 0 |
Tested with qgis trunk in both linux and windows.
a) open the selector, put the focus on the space where you can write the
name/auth.id and the click on "cancel", it will warn you that
"No matching projection found."
b) now if you want to search for a epsg code (or other authority code) you
can't simply search for (example) "4326" because it will return
you need to enter "epsg:4326" which is not very intuitive considering that
searching for names works in a different way -> it finds all the records
that match the search string.
I suggest to make the auth.id search work the same as the name search, or
at least add a dropdown to select the authority for auth.id searches.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2602>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
