[QGIS-trac] [Quantum GIS] #2689: Dealing with more sophisticated PostGIS table permissions
Quantum GIS qgis at qgis.org
Sun May 2 17:49:52 EDT 2010
   Reporter:  martin                            |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.5.0
  Component:  Data Provider                     |            Version:  HEAD
   Keywords:                                    |   Platform_version:
   Platform:  Debian                            |           Must_fix:  No
Status_info:  0                                 |
 See also: http://lists.osgeo.org/pipermail/qgis-developer/2010-
 April/009752.html
 I'm trying to make use of the nice PostgreSQL feature which allows me
 to grant different permissions on different columns of a table to the
 user.
 To be more precise, the table has a 'serial'-type "ogc_fid", a
 'geometry'-type "wkb_geometry" plus a few more columns, of which a
 'timestamp'-type column is filled via INSERT/UPDATE trigger.
 SELECT/DELETE is granted to the user on the _entire_ record, but
 INSERT/UPDATE is granted just on the "wkb_geometry" column.
 Everything's fine as long as I'm filling the table via 'ogr2ogr'
 ("-append"), the geometries are getting in, the serial and the trigger
 are filling their respective columns quite nicely. Thus I assume I've
 set the grant's properly  :-)
 Now, when trying to edit the layer in QGIS, we're permitted to move a
 vertex of a polygon ....  Well, I didn't try to save the result to the
 DB, but QGIS at least activates the note tool in edit mode - so I
 simply believe it's going to work.
 BUT we're not permitted to insert a new polygon (copied from a
 different layer) via the paste feature, as long as the grant's are set
 up as explained above. The paste item in the edit menu simply remains
 greyed out and Ctrl-V doesn't insert anything.
 The source layer of the planned copy-and-paste action is imported into
 QGIS from a Shapefile, of which I've removed the .dbf-file, and thus
 does _not_ contain any attributes which might conflict with the (write
 protected columns in the) target PostGIS layer.
 Granting INSERT/UPDATE on the entire record would serve as a
 workaround, but contradicts my plan of preserving the non-geometry
 columns agains unwanted edits.
 Can anyone confirm ? Any chance to let QGIS focus on the geometry
 column when retrieving table permissions from PostgreSQL while deciding
 over the permitted actions ?
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2689>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
