[QGIS-trac] Re: [Quantum GIS] #2468: Support for Column Permissions
in PostgreSQL 8.4
Quantum GIS
qgis at qgis.org
Sun May 2 18:08:37 EDT 2010
#2468: Support for Column Permissions in PostgreSQL 8.4
Reporter: pinux | Owner: nobody
Type: enhancement | Status: closed
Priority: major: does not work as expected | Milestone: Version 1.5.0
Component: Data Provider | Version: HEAD
Resolution: fixed | Keywords: postgis postgres column permission
Platform_version: | Platform: All
Must_fix: No | Status_info: 0
Changes (by jef):
* status: new => closed
* resolution: => fixed
Comment:
fixed in r13014.
the postgres provider now checks if the user has update privilege on the
geometry column when checking if geometry changes should be enabled and
update privileges on any/at least one attribute column to enable attribute
changes. Enabling addition of new features still requires table insert
privilege (ie. insert privilege on all columns).
Note: that way edits of readonly attribute columns are not forbidden, but
will cause the commit to fail. To prevent that either don't change those
attributes in the first place or set the read-only attributes 'Immutable'
or 'Hidden' in the attribute tab of vector layer properties, so that the
are not changeable in the UI - although plugins could still change
readonly attributes.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2468#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
