[QGIS-trac] Re: [Quantum GIS] #2444: Discrepancy between gdalinfo and QGIS raster metadata
Quantum GIS qgis at qgis.org
Mon May 3 18:18:45 EDT 2010
        Reporter:  alobo                             |         Owner:  nobody
            Type:  bug                               |        Status:  new
        Priority:  major: does not work as expected  |     Milestone:  Version 1.5.0
       Component:  Rasters                           |       Version:  HEAD
      Resolution:                                    |      Keywords:
Platform_version:                                    |      Platform:  Debian
        Must_fix:  No                                |   Status_info:  1
Comment (by brushtyler):
 I think there is not only one issue.
 First issue: [[BR]]
 Replying to [comment:10 alobo]:
 > 1. Interpolation plugin generates an Arc Ascii raster, even if it's
 named test2.tif
 why Interpolation plugin create an Arc Ascii named .tif? Do you have
 opened a ticket about this?
 Second (possible) issue: [[BR]]
 > 4. Then I used QGIS Raster/Assign projection to assign UTM31N ED50.  The
 projection
 > is assigned and the file converted to geotiff (without asking you)
 the gdal Assign Projection gui says:
 The output is:
 - new GeoTiff if input file is not GeoTiff
 - overwritten if input is GeoTiff
 It checks if is a GeoTiff by looking at the file extension, so it
 overwrite the input file.
 > So the problem is in Raster/Assign projection.
 > I still have to check if this happens with any Raster/ utility in QGIS,
 hope not.
 Assign Projection use gdalwarp. Have you tried to change the projection
 with another gdal executable (from shell)?
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2444#comment:11>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
