[QGIS-trac] Re: [Quantum GIS] #2620: (windows) v.out.ogr.pg does not start
Quantum GIS qgis at qgis.org
Thu May 6 13:27:37 EDT 2010
        Reporter:  lutra                             |         Owner:  rugginoso
            Type:  bug                               |        Status:  closed
        Priority:  major: does not work as expected  |     Milestone:  Version 1.5.0
       Component:  GRASS                             |       Version:  HEAD
      Resolution:  fixed                             |      Keywords:
Platform_version:                                    |      Platform:  Windows
        Must_fix:  No                                |   Status_info:  0
Changes (by jef):
  * status:  reopened => closed
  * resolution:  => fixed
Comment:
 Replying to [comment:2 pcav]:
 > It happens again, apparently:
 > Cannot start module db.connect-login.pg.py
 > command: C:/OSGeo4W/apps/qgis-unstable/./grass/scripts//db.connect-
 > login.pg.py --interface-description
 Not really.  Apparently you are using qgis-unstable (1.4) and not qgis-dev
 (trunk) which contains the fix.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2620#comment:3>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
