[QGIS-trac] Re: [Quantum GIS] #2411: FTBFS: qgsgrass.cpp + old
grasses on Debian/Lenny
Quantum GIS
qgis at qgis.org
Fri May 7 22:42:43 EDT 2010
#2411: FTBFS: qgsgrass.cpp + old grasses on Debian/Lenny
Reporter: hamish | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.5.0
Component: Build/Install | Version: HEAD
Resolution: | Keywords: grass
Platform_version: Lenny amd64 | Platform: Debian
Must_fix: No | Status_info: 0
Comment (by hamish):
Replying to [comment:9 jef]:
> Still spatialite should be optional: fixed in r13429.
great, I get past that .cpp file now, thanks.
Replying to [comment:10 jef]:
> You're supposed to add a changelog entry with distribution lenny
> (not stable)
"supposed"? as in specific to the qgis build scripts, right? for previous
backports of other software I've used the unstable/ testing/ stable/ old-
stable names without problem.
> and the rules will rebuild control from control.lenny replacing
> {QGIS_ABI} (and {GRASS_ABI}).
ok, done that. Now it gets past the main build but I get a weird linking
error I've not seen before. Here's the end of it:
- _ZThn8_N20QgsMapOverviewCanvasD0Ev at Base 1.5.0
- _ZThn8_N20QgsMapOverviewCanvasD1Ev at Base 1.5.0
- _ZThn8_N21QgsDetailedItemWidgetD0Ev at Base 1.5.0
- _ZThn8_N21QgsDetailedItemWidgetD1Ev at Base 1.5.0
- _ZThn8_N21QgsEncodingFileDialogD0Ev at Base 1.5.0
- _ZThn8_N21QgsEncodingFileDialogD1Ev at Base 1.5.0
- _ZThn8_N21QgsProjectionSelectorD0Ev at Base 1.5.0
- _ZThn8_N21QgsProjectionSelectorD1Ev at Base 1.5.0
- _ZThn8_N28QgsGenericProjectionSelectorD0Ev at Base 1.5.0
- _ZThn8_N28QgsGenericProjectionSelectorD1Ev at Base 1.5.0
+ _ZThn40_N19QgsCredentialDialog7requestE7QStringRS0_S1_S0_ at Base
1.5.0.lenny
+ _ZThn40_N19QgsCredentialDialogD0Ev at Base 1.5.0.lenny
+ _ZThn40_N19QgsCredentialDialogD1Ev at Base 1.5.0.lenny
+#MISSING: 1.5.0.lenny# _ZThn8_N12QgsMapCanvasD0Ev at Base 1.5.0
+#MISSING: 1.5.0.lenny# _ZThn8_N12QgsMapCanvasD1Ev at Base 1.5.0
+#MISSING: 1.5.0.lenny# _ZThn8_N14QgsColorButtonD0Ev at Base 1.5.0
+#MISSING: 1.5.0.lenny# _ZThn8_N14QgsColorButtonD1Ev at Base 1.5.0
+#MISSING: 1.5.0.lenny# _ZThn8_N15QgsComposerViewD0Ev at Base 1.5.0
+#MISSING: 1.5.0.lenny# _ZThn8_N15QgsComposerViewD1Ev at Base 1.5.0
+#MISSING: 1.5.0.lenny# _ZThn8_N15QgsFileDropEditD0Ev at Base 1.5.0
+#MISSING: 1.5.0.lenny# _ZThn8_N15QgsFileDropEditD1Ev at Base 1.5.0
+#MISSING: 1.5.0.lenny# _ZThn8_N16QgsMessageViewerD0Ev at Base 1.5.0
+#MISSING: 1.5.0.lenny# _ZThn8_N16QgsMessageViewerD1Ev at Base 1.5.0
+#MISSING: 1.5.0.lenny# _ZThn8_N16QgsPanningWidgetD0Ev at Base 1.5.0
+#MISSING: 1.5.0.lenny# _ZThn8_N16QgsPanningWidgetD1Ev at Base 1.5.0
+#MISSING: 1.5.0.lenny# _ZThn8_N20QgsMapOverviewCanvasD0Ev at Base 1.5.0
+#MISSING: 1.5.0.lenny# _ZThn8_N20QgsMapOverviewCanvasD1Ev at Base 1.5.0
+#MISSING: 1.5.0.lenny# _ZThn8_N21QgsDetailedItemWidgetD0Ev at Base 1.5.0
+#MISSING: 1.5.0.lenny# _ZThn8_N21QgsDetailedItemWidgetD1Ev at Base 1.5.0
+#MISSING: 1.5.0.lenny# _ZThn8_N21QgsEncodingFileDialogD0Ev at Base 1.5.0
+#MISSING: 1.5.0.lenny# _ZThn8_N21QgsEncodingFileDialogD1Ev at Base 1.5.0
+#MISSING: 1.5.0.lenny# _ZThn8_N21QgsProjectionSelectorD0Ev at Base 1.5.0
+#MISSING: 1.5.0.lenny# _ZThn8_N21QgsProjectionSelectorD1Ev at Base 1.5.0
+#MISSING: 1.5.0.lenny# _ZThn8_N28QgsGenericProjectionSelectorD0Ev at Base
1.5.0
+#MISSING: 1.5.0.lenny# _ZThn8_N28QgsGenericProjectionSelectorD1Ev at Base
1.5.0
_ZZN11QMetaTypeIdI19QgsDetailedItemDataE14qt_metatype_idEvE11metatype_id at Base
1.5.0
_ZZN11QMetaTypeIdI5QListIP7QWidgetEE14qt_metatype_idEvE11metatype_id at Base
1.5.0.lenny
+ _ZdlPvS_ at Base 1.5.0.lenny
+ _Zeq5QCharS_ at Base 1.5.0.lenny
+ _ZeqN7QString4NullERKS_ at Base 1.5.0.lenny
+ _ZeqPKcRK7QString at Base 1.5.0.lenny
+ _ZmiRK6QPointS1_ at Base 1.5.0.lenny
+ _ZmiRK7QPointFS1_ at Base 1.5.0.lenny
+ _ZneRK5QSizeS1_ at Base 1.5.0.lenny
+ _ZnwmPv at Base 1.5.0.lenny
+ _ZorN11QMessageBox14StandardButtonES0_ at Base 1.5.0.lenny
+ _ZorN16QDialogButtonBox14StandardButtonES0_ at Base 1.5.0.lenny
+ _ZorN17QAbstractItemView11EditTriggerES0_ at Base 1.5.0.lenny
+ _ZorN2Qt13AlignmentFlagES0_ at Base 1.5.0.lenny
+ _ZorN2Qt8ItemFlagES0_ at Base 1.5.0.lenny
+ _ZorN2Qt9MatchFlagES0_ at Base 1.5.0.lenny
_ZplPKcRK7QString at Base 1.5.0
+ _ZplRK7QPointFS1_ at Base 1.5.0.lenny
+ _ZplRK7QString5QChar at Base 1.5.0.lenny
_ZplRK7QStringPKc at Base 1.5.0
+ _ZplRK7QStringS1_ at Base 1.5.0.lenny
capture_point_cursor at Base 1.5.0
cross_hair_cursor at Base 1.5.0
identify_cursor at Base 1.5.0
dh_makeshlibs: command returned error code 256
make: *** [binary-arch] Error 1
debuild: fatal error at line 1301:
couldn't exec fakeroot debian/rules:
Apparently errors >3000 lines long so the start of it is beyond my
terminal buffer. I can rerun tee'ing stderr to a file if it helps.
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2411#comment:11>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
