[QGIS-trac] [Quantum GIS] #2700: Adding a layer from py plugin, with QgsVectorLayer.setEditFormInit (QString function) set
Quantum GIS qgis at qgis.org
Sat May 8 14:58:51 EDT 2010
function) set
   Reporter:  jaanussuvi                                 |              Owner:  borysiasty
       Type:  bug                                        |             Status:  new
   Priority:  critical: causes crash or data corruption  |          Milestone:  Version 1.5.0
  Component:  Python plugins and bindings                |            Version:  1.4.0
   Keywords:  QgsVectorLayer setEditFormInit             |   Platform_version:  Quantum GIS 1.4 -   code revision  12728
   Platform:  Windows                                    |           Must_fix:  Yes
Status_info:  0                                          |
 Briefly about my case:
 I created a python plugin,
 and it creates QgsVectorLayer's from Postgis database.
 I do add qml styles to my layers, with layer.loadNamedStyle(path_to_qml).
 And in qml i've specified form init functions in python
 <editforminit>myInitMethod</editforminit>
 I'm trying to initilize some data fields with editforminit function.
 The problem:[[BR]]
 1) i add a layer with my plugin
 2) select the added layer which has <editforminit> specified
 3) toggle the layer to edit mode
 4) try to add a layer object to map, click on the map
 5) then qgis always craches
 Problem is only when i have set editforminit function.
 [[BR]]
 [[BR]]
 but if i do
 steps
 * (save project)
 * (close and open qgis)
 before adding new object to my layer, then editforminit function is
 invoked and everything works.
 Maybe there's a workaround?
 Maybe some refreshing?
 I do after adding layers:
 self.iface.refreshLegend(myLayer)
 self.iface.mapCanvas().refresh()
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2700>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
