[QGIS-trac] [Quantum GIS] #2703: Incorrect rendering for vector
 line segments that span -180 line of longitude version 1.4.0
    Quantum GIS
    qgis at qgis.org
    Mon May 10 13:50:46 EDT 2010
#2703: Incorrect rendering for vector line segments that span -180 line of
   Reporter:  abigbee                                    |              Owner:  nobody
       Type:  bug                                        |             Status:  new
   Priority:  critical: causes crash or data corruption  |          Milestone:  Version 1.5.0
  Component:  Vectors                                    |            Version:  1.4.0
   Keywords:  vector rendering                           |   Platform_version:  Windows revision 12728
   Platform:  Windows                                    |           Must_fix:  Yes
Status_info:  0                                          |
 Polygons in vector layers that have line segments with endpoints that span
 the -180 line of longitude are incorrectly rendered.  For example, a line
 with endpoints of 1 degree and  -179 degree will not result in a 2 degree
 line, but rather be rendered as a line of of 180 degrees in length and
 spans. I.e. instead of a short line segment in the Pacific, the line runs
 across North America and the Atlantic.
 I have attached a small test case for a many-side polygon esri shape file
 that I programmatically generated to illustrate this bug.  Upon rendering
 in the GUI, the left side of the western polygon should incorrectly be
 extruded all the way across North America and the Atlantic Ocean.  The
 correct rendering would display a circle-like polygon centered on the
 Alaskan Aleutian Islands.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2703>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
